squeaking from front axle...
Old Jul 26, 2013 | 08:45 AM
troy5174's Avatar
Default squeaking from front axle...
I just bought a 2002 discovery 2 that makes a squeaking/ squealing noise when I let off the gas, and sometimes as I press the gas...sounds like it's coming from the front axle, any ideas? Please help
Old Jul 26, 2013 | 12:11 PM
mattmo78's Avatar
Could be your front drive shaft. My '04 would make a squealing noise as I drove also, pulled the front drive shaft out, had it rebuilt with grease zerks in the u-joints and it's been good to go.
Old Jul 26, 2013 | 12:29 PM
poncePR's Avatar
If its front drive shaft its about to say good-by and run away with your tranny!...Good luck!
Old Jul 26, 2013 | 12:34 PM
drowssap's Avatar
try posting a video
Old Jul 26, 2013 | 02:46 PM
I would stop driving it, if it is that bad, it may not make it thru the weekend and possibly punch a hole in the tranny to boot.
Also, axles can't or don't squeak.
Old Jul 27, 2013 | 05:23 PM
troy5174's Avatar
So I should replace the axle or the drive shaft?
Old Jul 27, 2013 | 06:28 PM
poncePR's Avatar
Look at your front driveshaft,should have a grease fitting on each universal(3).If so just grease & inspect them
If only 1 has a fitting you need to rebuild it or replace it.
Old Jul 27, 2013 | 08:27 PM
troy5174's Avatar
Thanks, will give it a shot
Old Jul 29, 2013 | 01:15 PM
troy5174's Avatar
I checked the drive shaft and u joints (even added grease to the fitting) everything seems to be tight and appear new,any other ideas?
Old Jul 29, 2013 | 01:32 PM
buick215's Avatar
How many grease fittings does your front drive shaft have? If it only has one I would replace it or rebuild it, even if it is not the cause of the squeaking. Your squeaking could be suspension bushings, ball joints or something else in the front suspension worn.
