squeaking from front axle...
Old Jul 29, 2013 | 01:56 PM
groeder24's Avatar
This is what you get when the front drive shaft breaks.
Old Jul 29, 2013 | 02:08 PM
poncePR's Avatar
If you plan on keeping your disco for some time,replace or rebuild your front driveshaft.Many have failed without warning.I rebuilt mine(Just for peace of mind,there were no noises) for less than $100 including beer.
Old Jul 30, 2013 | 09:35 AM
Charlie_V's Avatar
I had the same problem. It was the front u joint on the driveshaft. If you hear a chirping at lower speeds them it goes away at higher speeds I wouldn't drive it until you pull the shift (8 bolts) and look at the u joint. In my case I saw nothing wrong with it until I pulled it and then I could see exposed rod bearings. If the driveshaft fails you will get a lot of damage. A new one with greasable joints is worth the money if you still have the original one on your truck.
Old Jul 30, 2013 | 06:21 PM
jfall's Avatar
Jack it up and check for loose wheel bearings.
If the wheel bearings need lube, the metal to metal will degrade and you will get some clearance.
That way you can narrow it down.
If your drive shaft is greasable, just grease it.
That will squeak a lot before the U joint completely fails and it drops.
Old Aug 8, 2013 | 01:21 PM
troy5174's Avatar
I rebuilt the front drive shaft and the noise went away, I just wanted to say thanks to all of you for your input and advice! You guys are top notch, thanks again
Old Aug 8, 2013 | 01:27 PM
Did you replace the centering ball also.
Old Aug 9, 2013 | 05:07 AM
troy5174's Avatar
I took it to a friend to pull the bearing, but yes I rebuilt the the whole front shaft. I even lined up the grease fittings
Old Aug 13, 2013 | 05:24 PM
troy5174's Avatar
Does anyone know the watts of the stereo amp in the 2002 discovery?
Old Aug 31, 2013 | 01:18 PM
troy5174's Avatar
after rebuilding the front drive shaft, the squeaking noise went away. But I find that my disco2 has a slight vibration that starts around 35 miles an hour and the vehicle passed inspection fairly easy (meaning that the brakes and rotors passed, tires passed...Any ideas or suggestions on what could be causing the problem? Any advice would be greatly appreciated-thanks
Old Sep 1, 2013 | 08:25 AM
mattmo78's Avatar
Did you rebuild the drive shaft or have it done? If you built it, did you get it aligned? Once rebuilt, I believe everything has to be balanced, and from what I understand, only a shop can do that. But, I could be wrong. That may be your issue, though. You could take it to a driveshaft shop and see if it is out of balance.
