"squeaking under load"
Old Oct 29, 2014 | 07:27 AM
  #21
drowssap's Avatar
try the search i just came across it not long ago
Old Oct 29, 2014 | 08:49 AM
  #22
bmeier's Avatar
Default squeaking
I'll be able to pull the belt off in a few hours
So any input would be greatly appreciated on these bearings, I read that the 80mm idler takes the 6304 bearing and the 70mm & tensioner pulley take a 6203. Just making sure those are correct
Old Oct 29, 2014 | 10:16 AM
  #23
bmeier's Avatar
Default belt
Pulled belt, drove still getting squeak, should i be looking more for a vacuum leak/ gasket leak something of that nature??
Old Oct 29, 2014 | 10:40 AM
  #24
Two Rock's Avatar
With the belt still off to eliminate extraneous noise, while under the hood with the engine running in park rev the motor at the throttle body and try to located the source of the sound, sounds like it could be a small exhaust leak between a head and one port of one of the exhaust manifolds, but maybe not. Again, do not do this for long, only like 20 seconds or so tops on a cold motor.
Old Oct 29, 2014 | 12:37 PM
  #25
bmeier's Avatar
It appears to be coming from up top near the intake manifold to the left of the brake booster those vacuum lines and such, I'm looking for any damaged vacuum lines and loose fittings, post a new vid in a minute.
Old Oct 29, 2014 | 02:05 PM
  #26
bmeier's Avatar
Default leak
Seems like its coming from in this area, cant really tell if its the exhaust manifold or up higher, trying to pinpoint exactly, but it will only squeak with fast acceleration while in Park. When it's in Drive just feathering gas will produce the squeak, this is the most aggravating leak Ive ever encountered.
Old Oct 29, 2014 | 08:05 PM
  #27
Two Rock's Avatar
Try a length of hose to your ear to isolate the sound on the engine, sounds like your close to finding it
Old Oct 30, 2014 | 06:45 AM
  #28
drowssap's Avatar
have someone block the exhaust with a rag and see if you hear the noise increase in volume.
Old Oct 30, 2014 | 03:39 PM
  #29
bmeier's Avatar
Thats a good idea, Ill try the rag, I'm kinda worried it might be a blown head gasket I might go get a test kit just to eliminate that.
Old Oct 31, 2014 | 01:04 PM
  #30
bmeier's Avatar
Did a smoke test, no leaks detected. I'm getting a p0174 code now. Still squeaking......
