Squeeky Breaks NORMAL or NOT?
Old Apr 13, 2005 | 04:42 PM
DIMISA1977's Avatar
Default Squeeky Breaks NORMAL or NOT?
I have an 03 Disco bought certified with 25000 miles. The rear pads were replaced and the front pads are said to have 90% left.
Yet, I hear an annoying squeek from the front passenger's brake.
I brought it to the dealer and they told me due to the fact that it is a metallic disc brake system the squeeks are normal...
ANY FEEDBACK FROM OWNER/DRIVERS here at the forum? Any help would really put my mind at ease.
MANY THANKS! J.P.
Old Apr 13, 2005 | 05:23 PM
mikemeyer0's Avatar
Default RE: Squeeky Breaks NORMAL or NOT?
I don't know about what the dealer told you, but you could have leftover brake material in there causing it. Pull tire off and check pads out, also hit em with a little brake cleaner. The one time i talked to the dealer about a prob. he pretty muched B.S.'d me an was wrong.
Old Apr 13, 2005 | 11:57 PM
Bait's Avatar
Normal, try doing A few aggressive stops in A safe area. This will take the glaze off. The brakes are designed to be used aggressively. If you use them lightly, they will make noise.
Old Apr 14, 2005 | 01:06 AM
kumbhani123's Avatar
if you have the warranty on it, just get it checked i mean to be on the safe side.
Old Apr 14, 2005 | 09:00 AM
DIMISA1977's Avatar
i do have the warranty...i drove up to my local dealer (during lunch hour) it takes about 45 minutes to get there...and he tells me "there's nothing i can do, this is normal."
i was like, "maybe you should have told me that when i booked the appt.?"
which leads me to my next post...please check forum...
Old Apr 20, 2005 | 05:13 PM
4x44me's Avatar
are your front brake discs scored as we have had a few where they make squeak noise but not after skimming the discs..
Old Apr 21, 2005 | 03:14 PM
troverman's Avatar
Right, people pay 45k for a rig that has the brakes squeal. Neither my 92 RRC or my 95 P38 have ever squeaked the brakes.
Old May 6, 2005 | 04:22 PM
mmeyer's Avatar
you could remove the brake pads and coat the back side of them with anti-sqeek compound. it always works for my cars
gbob
Mar 1, 2014 09:40 AM
gbob
Feb 25, 2014 08:07 PM
suveer
Mar 26, 2007 01:47 PM
Discofan
Nov 29, 2005 12:32 AM
barryd
Nov 6, 2005 07:10 PM
