Squeeling Hub
Old Sep 13, 2009 | 04:03 PM
unstable's Avatar
Default Squeeling Hub
Being that there are no replaceable bearings on the Disco II, I'm figuring that the hub is going to need to be replaced...unless there's a way of greasing it up or spraying some $20 Land Rover oil into it or something.
Opinions? Sources for cheap hubs?
Old Sep 13, 2009 | 04:08 PM
NiteTrain's Avatar
unit bearing, no way to grease. The whole hub assembly has to be replaced ($400). If it's squealing I wouldn't dive it until repaired.
Old Sep 13, 2009 | 04:12 PM
You do need to stop driving it or you will do additional damage and the parts will will just keep getting bigger.
Are you going for a new or used hub?
Old Sep 13, 2009 | 07:24 PM
lipadj46's Avatar
Roverland Parts has good used hubs kind of pricey though. Rovers North has proline hubs on sale for $300 quite often.
Old Sep 13, 2009 | 09:41 PM
unstable's Avatar
sonofabitch.
what next?
Just dropped $300 on a new coil job on this god forsaken vehicle...seriously? I have to say that English Engineering just downright sucks ***.
Thanks for the heads up though guys...nothing against you.
Old Sep 13, 2009 | 10:01 PM
NiteTrain's Avatar
unstable, I know how ya feel. I thought I needed a new one a few months back, I was cussing LR. It's not just LR, I think any vehicle made in the past 10 years uses unit bearings. They just go out more often on off-road vehicles because of sand and mud.
Old Sep 14, 2009 | 08:08 AM
unstable's Avatar
I'm just a little frustrated is all...I mean it's a cool rig and my wife says it's her "DREAM CAR"...my dream car is a 1957 Chevy Pickup truck with a 454 CID in it...which I own but it's in about 1000 pieces...or maybe a Dodge Viper would be cool.
I put in the extra effort because it is my wife's rig and it makes her happy having her "dream car"...know what I mean? But really it pisses me off the way things have been going with this truck. We don't take it off road so I wouldn't expect the hubs to go at 73,000 miles. I just spent $250 for a new coil and $40 for the intake gasket and now I had to drop another $300 for the hub this morning. Just a few months ago I had to do the timing chain cover, water pump and timing chain...Then a few months before that I somehow sprang a leak in two tires on the sidewall...not off roading and that cost me another $300 or so...it just stinks...it really stinks. I'm not happy about having to rip the intake manifold off to replace the coil. I'm pissed off at magnecor because I highly suspect that half of the wires I bought from them were missing the snap clips that hold the wire to the coil terminal...I'm going to call them this morning in fact.
Old Sep 14, 2009 | 10:44 AM
leadfoot's Avatar
Unstable, you got every reason to be upset. It sounds like you got a lemon.
70+K for a hub bearing without off-roading is a premature failure. My advise is to really make sure that the hub bearing is what is causing the noise, and not brakes or something else.
Old Sep 14, 2009 | 11:33 AM
unstable's Avatar
I'm 99% sure it's the hub. It's not constant and it's not a typical brake noise. Initially I thought it was a wheel-bearing, which it is technically...so I did the old "rock the steering wheel back and forth" trick to see if I could definitely identify it...and it's driver's side front. It's not a constant squeel but when it kicks in, all of the dogs in the neighborhood start following the truck around.
Brakes are all new. I ordered the hub because I've got a road trip on Thursday that requires the rover. If I start tearing into it and find that it's not the hub, I'll simply return it for a refund. If it is the hub, I'll have it on hand and I can slap the new one in.
Whoever recommended Rover's North, thanks...saved me $100 going with the proline hub.
Old Sep 14, 2009 | 01:19 PM
NiteTrain's Avatar
unstable, look on the bright side..at least your wife's dream car isn't a 2010 range rover and the $800/mo. payments that come with it.
A hub going out at 73K miles does sound very odd to me if it's never been off-road. Are you the original owner and know for certain it's never been off-road? I have a friend that bought a new Jeep rubicon. He takes it off-road a lot and sometimes in mud, both his unit bearings went out under 30k miles.
