squeky brakes causing abs issue??
Old Nov 15, 2013 | 10:42 PM
FlyingZebra34's Avatar
Default squeky brakes causing abs issue??
This morning I was driving though a dirt lot to our job site and the the amigos came back as I was pressing on the brakes. They were very squeaky from all the dust.
This has happened twice now and they won't turn off now.
I'm saving some money so hopefully I can get a scan to to keep on hand after I rebuild the front driveshaft and get a new windscreen.
I was curious if anyone else has noticed anything similar?
Old Nov 16, 2013 | 01:47 PM
ninjaff21's Avatar
Yes the squeaky breaks can trigger the abs amigos. While my p1590 was believed to just be a computer error i still think part of it had to do with squeaky breaks.
Old Nov 16, 2013 | 09:25 PM
Do ceramic brakes solve this problem??
Old Nov 17, 2013 | 10:17 AM
ninjaff21's Avatar
Im not 100% on the ceramic brakes because i have not changed over yet but mike told me akebonos euro676 and euro 493 on amazon should solve the break dust/squeak problem
Old Nov 18, 2013 | 06:28 AM
jfall's Avatar
My brakes squeal like stuck pigs.
No ABS error code lights on at all.
Old Nov 18, 2013 | 08:57 AM
We can't all be lucky jfall
I should have my altel scanner by the end of the week so ill know the codes.
Old Nov 18, 2013 | 12:39 PM
drowssap's Avatar
if you need pads go ceramic if not buy a bottle of permatex brake pad cement, clean the pads and calipers put on the permatex and the noise will go away
Old Nov 18, 2013 | 03:57 PM
ninjaff21's Avatar
get the CDP+ scanner unless u already bought that one
Old Nov 18, 2013 | 07:40 PM
SuperSport's Avatar
Same issue with squeaky brakes. If you use the Scan Gage and clear OBDII code right when it happens, the 3 Amigos won't stick permanently.. If you wait too long, they stick and you need an ABS scanner. I've been lazy and have not removed them to permatex. I have CDP+ now, so am able to clear when it happens. I've been wondering if and adjustment to the sensor spacing would prevent this on future squealing.
Old Nov 18, 2013 | 07:48 PM
jafir's Avatar
What codes do you get from the abs computer?
