SRS light on
Old May 6, 2013 | 07:19 AM
English Geoff's Avatar
Default SRS light on
Guys i wonder if anyone can shed some light on this fault? I have plugged the hawkeye in and on the airbag screen the fauly shows as a permanent fault? it doesnt show any codes at all??
Am i doing something wrong or is it a major earth fault on the airbag system?
Thanks in advance for any help on this!!!
Old May 6, 2013 | 07:43 AM
drowssap's Avatar
"SRS light on"
Old May 6, 2013 | 07:52 AM
Read that one wrong.
With that sort of a code, start with the basics, check your connections at all belts and possible grounds.
Old May 6, 2013 | 07:57 AM
Thanks Mike,
I have checked all the connections, split them cleaned them and put dielectric grease on the pins on the seat belt tensioners and the passenger side aire bag, when i bought the car it had the light on, it looks like it may have had a bump in a previous life, is it possible the control unit has been activated and needs replacing?
Thanks
Old May 6, 2013 | 08:43 AM
Yes, it is possible, but if it had activated, the bag would have had to be replaced.
If all else fails, Roverlandparts.com has guaranteed used SRS ECU's for $95 and Paul Grant most likely has them for less.
Old May 6, 2013 | 09:16 AM
Thanks Guys, I will give it a go and see if that works.
robdis96
May 21, 2007 08:05 PM
RJADM2000
Dec 11, 2006 06:59 PM
bphiggins
Aug 21, 2006 12:31 PM
Rovercountry
Dec 25, 2005 09:42 AM
anonimaus
Mar 14, 2005 12:39 AM
