Stall in Idle
Still dead in the driveway. Tested the electrical connection the circuit has voltage in the relay and fuse on the engine compartment but no current at the plug. Took the pump out and tested it outside just to make sure the pump is not defective and it worked fine. If the CPS is defective will I still get voltage in the relay? If no then there must be another location where the current is interrupted?
