Stalling/Fuel Pump Questions
I am having an issue with stalling in D, may stall in other gears, but have not witnessed it. Happens once a drive, usually towards the beginning engine is warming up, and it starts back up.
When starting back up I have to push the accelerator to get it to start, which upon first start up it does not have to.
The only other symptom which may relate is that the gas gauge rises as it warms up, it is very cold in Chicago right now.
My questions are if this has happened to anyone else, and the fix obviously. To me, it seems like the fuel pump is starting to go. I am going to stop at Autozone and get a fuel pump tester today, and do a little research in the RAVE.
I just went out and checked the Fuel Gauge against the Ultragauge Blue. The gauge on the dash is reading a bit over 1/4 tank and the Ultragauge 15 Gallon or 58% full.
The last time it stalled it had more gas than now, and the time prior much less. I am wondering if the malfunction is sending an error and stalling.
Going to research now.
Just recently cleaned my IAC. Maybe she is on the way on out. Did that one start up again right away?
