Standard vs. Synthetic oil ?
Old Aug 25, 2011 | 09:58 AM
wheelgarage's Avatar
This subject is discussed by every car forum out there in the world. There is no doubt that synthetic oil will out perform regular motor oil, in wear and cleanliness.
From breaking down a many rotary engines, two-strokes, and four-strokes, I have seen what both can do to an engine. There are many variances of why engines leak, so that is a moot point. Yeah, synthetics ability to provide wear resistance, obviously.
Also, we should all know what gasoline naturally does in an engine besides combust, it creates carbon. What I notice between the oils are two things, the flash point and the control of carbon. Synthetics will out perform by providing better control of those two issue, which = a cleaner and better running engine.
Old Aug 25, 2011 | 11:10 AM
IMHO the marketting departments have convinced many people that with synthetics they won't need to change oils so often, and that may be true, but many users expand that to unreasonable times, especially when the same size filter only holds so much gunk. Change early and often, do't go 7500 miles on it, and use a diesel rated oil (Rotella, Delvac, etc.) for the cleaning you need. We are driving a truck, 40 or 50 weight oil. 10W40 rated in this vehicle for -10 to +55 C, which covers a lot of territory. 10W30 has no improvement on low temp rating, and reduces high temp rating, so why bother? 5W40 is a good winter choice if you need that "nip in the air" performance.
Old Aug 25, 2011 | 05:20 PM
buick215's Avatar
Originally Posted by KBW
I had a tick that went away after switching to Royal purple...sure it started leaking and did so for a few months but that stopped and my it runs a lot better
Royal Purple and Amsoil are one of the few oils that are 100% synthetic. Mobil 1 is not even a full synthetic oil, it only has synthetic detergents just like most other "synthetic" oils. That is one of the reasons why I use regular Rotella and change it every 4-5k miles. Most synthetic oils are a racquet if you ask me.
Old Aug 25, 2011 | 08:31 PM
Originally Posted by buick215
royal purple and amsoil are one of the few oils that are 100% synthetic. Mobil 1 is not even a full synthetic oil, it only has synthetic detergents just like most other "synthetic" oils. That is one of the reasons why i use regular rotella and change it every 4-5k miles. Most synthetic oils are a racquet if you ask me.
exactly!!!!
Old Aug 25, 2011 | 08:33 PM
Originally Posted by rovernoy
So if synthetics are good for extreme cold temps what would be good for extreme heat? I'm in vegas and have about maybe 2 1/2 more months of 100-90 weather.
A good heavy duty oil, like diesel oil, 15w-40 would be perfect for you.
If it can hold up to a truck pulling 80,000lbs up a steep grade in 100*F heat it can stand up to your Rover idling in the drive thru in 100*F heat.
Old Aug 25, 2011 | 10:16 PM
disc oh no's Avatar
Just out of curiousity Spike, what do you use for oil filters again? I think I've seen that info. posted somewhere but can't remember on what thread. Just wondering, with the amount of miles you've got, it seems you're doing something (quite a few things) right!
Old Aug 26, 2011 | 09:41 PM
NAPA and Purolator oil filters, standard size
If you keep your eyes open NAPA runs BOGO sales and I stock up when they do.
Alot of guys run the larger oil filter, I do not although I have nothing against doing it.
Old Aug 26, 2011 | 10:02 PM
disc oh no's Avatar
Thanks for the info. Spike. How do these NAPA and Purolator oil filters stack up against Mobil1 or Bosch or K&N? Don't they have some rating like... so many microns it can catch or something like that. I don't know the exact terminology or whatever but, are they comparable to these filters or are these more expensive filters truly any better? Just curious, Thanks again.
Old Aug 26, 2011 | 10:10 PM
WIX 51459 provides 1.3 quarts of capacity, seven inches long. It is not as fine a mesh filter as the Mobile 1, which can go down to 10 microns. But if you are changing often, you are reducing that need, especially if you are the last in a long line of owners. It is also carried as NAPA Gold.
Old Aug 26, 2011 | 10:40 PM
lordmorpheus's Avatar
FWIW I run a Wix 51515 in my D2 for the larger capacity. I'll try to remember to check the Wix catalog for micron rating at work tomorrow.
Quick search of Wix website shows 21 micron, 7-9GPM, drain-back valve, 8-11PSI bypass valve setting
