Started Truck, no PWR to windows, lights or radio
Old Apr 14, 2009 | 08:41 PM
Frank4's Avatar
I am going to see if Disco Mike can get on this.
Old Apr 14, 2009 | 08:50 PM
PLEASE post the fix so that others with this same/similar problem can be helped.
Old Apr 14, 2009 | 08:51 PM
Frank4's Avatar
I will, that is something that is missing from this forum.
Old Apr 14, 2009 | 09:03 PM
Suede's Avatar
You mentioned that you tried to jump it with no luck. Just so you can rule out something as simple as a bad battery, take the battery from your other vehicle and put it in the Disco. If you're still getting no action on the starter, eliminate the next thing in line - an internally corroded ground cable on the battery. Disconnect the ground cable and bend it about every inch to feel if it is brittle anywhere. A bad cable can provide enough grounding for your radio - but still be too corroded to ground the starter.
Old Apr 14, 2009 | 09:14 PM
Frank4's Avatar
The battery is 3 months old. Ok, can someone connect the dots between #1. the power features not working when the truck STARTED and only working again when the truck was immediately turned off and restarted. AND #2 the truck not starting and the power features working.
Old Apr 15, 2009 | 06:49 AM
redhotbuzz's Avatar
make sure after you start it your key springs back to the on position
justinelam1313
Jul 4, 2012 11:14 PM
kman3786
Jun 20, 2012 11:06 AM
rimasco
Feb 28, 2012 04:32 PM
rangerover88
Oct 2, 2006 06:14 PM
