Starter installation advice
I recently pulled my starter out of my Discovery. I had intermittent issues with starting and after eliminating any electrical issues I pulled it. After pulling and inspecting, the metal cap on the Bendix (the part below the toothed gear) looks like a woodchuck had been chewing on it.
I inspected the Flex Plate and didn't see anything wrong there. But clearly the Flex Plate was able to touch and chew up this portion of the starter.
I then bought a rebuilt Bosch starter but I do not want to run into the same issue with my new starter. Clearly there where some clearance issues between the starter Bendix and the Flex Plate. The previous starter was a cheap starter so it could have been that the tolerances where out of spec.
Anyway I wonder if installing some shims would be a good idea or even necessary with this new starter?
