Starter installation advice
Old Mar 30, 2014 | 11:48 AM
chicane's Avatar
Question Starter installation advice
I recently pulled my starter out of my Discovery. I had intermittent issues with starting and after eliminating any electrical issues I pulled it. After pulling and inspecting, the metal cap on the Bendix (the part below the toothed gear) looks like a woodchuck had been chewing on it.
I inspected the Flex Plate and didn't see anything wrong there. But clearly the Flex Plate was able to touch and chew up this portion of the starter.
I then bought a rebuilt Bosch starter but I do not want to run into the same issue with my new starter. Clearly there where some clearance issues between the starter Bendix and the Flex Plate. The previous starter was a cheap starter so it could have been that the tolerances where out of spec.
Anyway I wonder if installing some shims would be a good idea or even necessary with this new starter?
Old Mar 30, 2014 | 12:35 PM
tuercas viejas's Avatar
First don't install shims
Most likely the aftermarket starter you had on there was not to spec.
Simply install your new one and go for a crank !
If there are no clashing noises don't worry!
The engine/ flywheel does not have a tight enough tolerance to affect anything in that area.
T/V
Gimebakmybulits
Jul 14, 2014 05:57 PM
nateandnikki
Jul 2, 2013 06:38 AM
johnkbl
Apr 23, 2012 07:49 PM
BFox15
Aug 21, 2011 08:48 PM
tex599
Oct 29, 2008 08:36 AM
