Starter Problem
Old Apr 19, 2010 | 12:09 PM
gmutis's Avatar
Default Starter Problem
I recently changed the fuel pump, as my DII would die on me for no reason, after checking with my local mechanic it was due to a faulty fuel pump.
I proceeded to change the pump, however, my DII would start ok in the morning (cold-start), but if I turned it off and then tried to turn it later on after an hour or so it wouldnt start, I would have to wait until next morning, and then it would start OK.
Right my DII is at the mechanic so I would appreciate your input to solve this bizarre issue.
Old Apr 19, 2010 | 12:23 PM
SO while driving it will just shut off and then not restart for a hour or two?
Or can you drive it for hours on end and then shut it off and it wont restart?
Old Apr 19, 2010 | 12:51 PM
gmutis's Avatar
The second one : I can drive for hours, shut it off, and then it wont restart........
Old Apr 19, 2010 | 01:36 PM
Suede's Avatar
That's the typical symptom of a failing Crank Position sensor. Starts fine cold, but can't restart when warm. Let sit for a few hours then it starts again. As the sensor continue failing it'll eventually start stalling after about 20 minutes of driving. I'd have the mechanic have a look at it. It's an easy thing to check / replace.
Old Apr 19, 2010 | 04:41 PM
Have your guy replace the crank sensor, its a $60 part.
Old Apr 27, 2010 | 11:29 AM
gmutis's Avatar
As you said, Temp and Crankshaft sensor showed up on the ODBII computer so I ordered the crankshaft sensor from Atlantic British $90+ a temp sensor $20 including transport to Colombia, I also changed sparkplugs (current ones had a nasty black color) and since I was shopping I bought the Magnecor ignition wire set to complete a nice ignition maintenance.
I will let you know next week how the repair ges.
Thanks for all you help,
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
felipenaves
Nov 19, 2007 07:53 AM
taffy nick
Feb 9, 2007 05:39 AM
