Starters any brands to avoid ?
Yep, no sure if my bad luck or what here. I typically will only purchase OE parts to reduce the risk or bad quality parts. I don’t think it my truck (wiring, mechanical) and I do have the stock heat shield installed.
My issue each time was intermittent no crank. No click or anything. Last time for sure I thought it was something else (ignition switch, relay, wiring) but it turned out to be another failed starter. Good thing is that the Bosch rebuild carries a two year replacement. I kept that as a spare.
That's hilarious, I avoid OEM anything on these because of their long track record of being bad quality lol
