Starting front end work, need guidance
I have a 2004 Disco, 83k, body and engine are great, but a lot of rust do to it sitting. I'm starting with the front end as I'm getting a lot of swaying, mechanic said I'll need to replace control arm and inner outer tie rods. Can anyone recommend what else I should look to change while I'm down there.
Thank you all!
Stefan
Thank you all!
Stefan
Received 1,188 Likes
on
You need a new mechanic...there are no control arms or inner tie-rod ends...only a right and left. Vehicles with rack and pinion have inner and outer tie-rods...and you don't have that. You have a steering gearbox, pitman arn, drag-link, steering stabilizer shock, ball-joints (upper and lower), tie-rod bar and ends that make up your steering components. You also have suspension components that can also affect steering geometry, such as panhard/track rod, springs, shocks and radius arm bushings.
Now, just for reference only...the british uses different terms for some of these components. For instance...they call tie-rod ends ball joints, they call the tie-bar a track bar...and so on and so on. So, it can get a bit confusing ordering parts or talking to different techs/mechanics about items needed. Odds are, you go to a general repair facility...they will use American terms...british specialty shop...most-likely british terms.
Thank you all!
Stefan
Thank you all!
Stefan
You mentioned rust check the rear frame welds before you waste your money, if it's rotted out it will need to be addressed
Thank you all!
Stefan
Thank you all!
Stefan
You mentioned rust check the rear frame welds before you waste your money, if it's rotted out it will need to be addressed.
Apart from front end, jackup the truck and check for play in the front end
If you don't have 'big tools' - like long breaker bars, big torque wrenches, sockets in the 19-30mm range, 1/2" drive things, you should get some. Working on the disco's suspension will be infinitely easier with them. It's indeed a very simple suspension system to work on, but some of those big bolts benefit from lots of leverage... that beast of a bolt holding the radius arm to the frame, for example.
