Starting front end work, need guidance
Old Jan 8, 2021 | 03:22 PM
stefanas's Avatar
Default Starting front end work, need guidance
I have a 2004 Disco, 83k, body and engine are great, but a lot of rust do to it sitting. I'm starting with the front end as I'm getting a lot of swaying, mechanic said I'll need to replace control arm and inner outer tie rods. Can anyone recommend what else I should look to change while I'm down there.
Thank you all!
Stefan
Old Jan 8, 2021 | 04:36 PM
zski128's Avatar
Control arm? Do you mean pitman arm? Other than the rust what drivability issues do you have?
Old Jan 9, 2021 | 03:44 AM
The Deputy's Avatar
You need a new mechanic...there are no control arms or inner tie-rod ends...only a right and left. Vehicles with rack and pinion have inner and outer tie-rods...and you don't have that. You have a steering gearbox, pitman arn, drag-link, steering stabilizer shock, ball-joints (upper and lower), tie-rod bar and ends that make up your steering components. You also have suspension components that can also affect steering geometry, such as panhard/track rod, springs, shocks and radius arm bushings.
Now, just for reference only...the british uses different terms for some of these components. For instance...they call tie-rod ends ball joints, they call the tie-bar a track bar...and so on and so on. So, it can get a bit confusing ordering parts or talking to different techs/mechanics about items needed. Odds are, you go to a general repair facility...they will use American terms...british specialty shop...most-likely british terms.
Old Jan 9, 2021 | 02:40 PM
NickS's Avatar
Thank you all!
Stefan
The front end is pretty stupid easy.
You mentioned rust check the rear frame welds before you waste your money, if it's rotted out it will need to be addressed
Old Jan 9, 2021 | 02:55 PM
NickS's Avatar
Thank you all!
Stefan
You mentioned rust check the rear frame welds before you waste your money, if it's rotted out it will need to be addressed.
Apart from front end, jackup the truck and check for play in the front end
Old Jan 10, 2021 | 11:52 PM
Brandon318's Avatar
If you don't have 'big tools' - like long breaker bars, big torque wrenches, sockets in the 19-30mm range, 1/2" drive things, you should get some. Working on the disco's suspension will be infinitely easier with them. It's indeed a very simple suspension system to work on, but some of those big bolts benefit from lots of leverage... that beast of a bolt holding the radius arm to the frame, for example.
merebel
Mar 9, 2019 02:46 PM
DiscoCam
Jun 24, 2016 12:03 PM
DiscoCam
Oct 7, 2015 07:17 AM
TRIARII
Feb 21, 2013 10:33 PM
Cottrell
Sep 20, 2012 01:24 PM
