Starting Issue?
Old May 19, 2011 | 05:49 PM
kjgale's Avatar
8th Gear
Question Starting Issue?
I have a 2002 LR Disco II with 131000 miles.
I just replaced the wires and plugs with parts recommended here.
I still have a problem with starting which has been happening since last June after I towed a pop up camper about 200 miles. When I go to start the the truck cold, it takes 3 times for the engine to kick over. Warm, I can shut her down and restart it right away.
Any suggestions?
Thanks in advance,
K
Old May 19, 2011 | 07:26 PM
DarylJ's Avatar
Check your fuel rail pressure cold (and hot). It could be a fuel pressure regulator that is leaking down overnight. If the rail pressure is good, it could be any number of items that can "solve" themselves when warm, like bad injectors, bad electrical connections to the injectors, poor connections to the coils (not the plug wires, the harness connections).
This is assuming that nothing else is happening that you didn't menton, like losing coolant. Or low voltage/weak battery causing it to crank too slowly.
I'm sure others will have some ideas as well.
Old May 19, 2011 | 08:12 PM
kjgale's Avatar
8th Gear
No issue with losing coolant or a weak battery. It cranks very strong. It is 3 times every time. I can crank it for 10 seconds or 1 minute each time, but it still takes 3 times, leading me to believe it is a sensor of some type.
K
Old May 19, 2011 | 08:23 PM
You need to do 2 things next time this happens.
First is to check for spark.
If that is good then check for fuel pressure at the engine.
Old May 19, 2011 | 08:41 PM
sloan74's Avatar
Also you can try to turn the key on and let it sit in the on position for a few seconds to make sure the fuel is primed. Then turn the key all the way to try and start it.
It's weird you say 3 times though. That's odd the way you described it. Could be something else that has nothing to do with spark or fuel. Maye someone else can chime in.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
chargersfan
Jan 6, 2009 06:08 PM
alsuch
Apr 20, 2008 09:09 PM
rravenn13
Aug 18, 2007 10:04 PM
Rob84
Feb 7, 2007 08:49 PM
