Starting issue
Starting issue
Sorry if this is covered somewhere but I couldnt find anything that seemed to match my problem.
For the past week when starting the car the following occurs: (temp doesnt make a difference)
1st key turn = starter turns slowly as if battery is weak
2nd key turn = same or slight better but doesnt start
3rd key turn = car starts fine as if everything is perfectly normal
I had the battery tested by two seperate shops and both said battery was good. Given the test results I elected to check all connections. I tightened the battery terminals (didnt' take much) and the starting issues went away for about 2 days.
This morning the symptoms came back except this time there was a major difference:
2nd key turn = lights on dash lit up @ half key turn then went off @ full key turn. Starter never even engaged. Like battery is completely dead.
I hooked jumper cables to car and still nothing happens. I'm assuming that even if the connection is poor or the cables are bad that the car would at least turn over when connected to jumper cables.
Anyone have any clues?
How about try the rest of the connections?
In the fuse box under hood - every large cable that is held down with a screw or bolt.
The positive battery cable - remove, clean, and re-tighten connectors at each end (battery and starter).
The negative battery cable - clean up and re-tighten on the battery, then follow that big black cable and clean up and tighten every place it connects to frame of truck.
At 300 amps draw, it only takes a dirty connection to drop plenty of volts to the starter, and such a connection can react to heat, etc.
alsuch
04-20-2008 09:09 PM
Rob84
02-07-2007 08:49 PM
