Starting issues
OK, as you I doubt its a computer issue.
If you mechanic does not have the proper ability to diagnose the problem, and you want to throw parts at it, I would change out the Crank Position Sensor.
Since you mechanic is not well versed in LR, you need to make sure he puts it on correctly, sensor, Spacers, nuts.
Good luck
Good luck
Like Abran mentioned, crank position sensor. Im my experience, the trucks starts and runs with no problem. Then, i stopped and wont crank anymore. I waited till engine cools up and starts again. Worst scenario is while youre driving and stalls. Had that before and even bought a fuel pump.
