On starting, only click, no crank, all power dies
Old Apr 10, 2023 | 07:58 PM
RoverMouse's Avatar
Default On starting, only click, no crank, all power dies
Hi,
I have a 2001 Land Rover Discovery 2. When I put the key in the vehicle all the lights turn on in the vehicle, but when I turn the key all the way to start, I hear a quick click and then all power is suddenly lost to the vehicle. Nothing works. It does not restore unless I disconnect the battery for a while. But the same thing happens when trying again. I installed a new battery and charged it. Same thing.
It's been down for a while, but a couple days ago I turned the key and it started straight up. Today I turned the key and it immediately died.
Any thoughts why it dies suddenly?
Thanks for the help.
Old Apr 10, 2023 | 08:41 PM
Best4x4's Avatar
I would inspect the quality of your battery terminals. When a D2 has power, then you try to start it, and you end up with absolutely nothing that's a classic sign you either have dirty/broken battery +/- leads, bad ground, or a dead/low charged battery.
Old Apr 11, 2023 | 08:18 AM
ahab's Avatar
Also check the ground cable that attaches to the bracket behind the belt tensioner.
Old Apr 11, 2023 | 09:19 AM
adalton's Avatar
I second both of the previous replies, I had the same issue and it ended up being a loose terminal connection on the negative post. I would take off both terminals and clean them, and then check the ground. Make sure both of the terminals do not move at all and have no corrosion. This should fix the problem.
Old Apr 12, 2023 | 10:52 PM
Frank4's Avatar
I had the exact same issue. Took a small file and cleaned the INSIDE of both the positive and negative connections. No more issues.0
Toran
Nov 8, 2021 06:06 PM
Amiee Pentzer
Range Rover L322 (3rd Gen)
Apr 1, 2020 11:04 AM
pvenuti
Nov 5, 2019 06:17 PM
dkstelling
Feb 18, 2019 01:55 PM
Dave Haynes
Jan 21, 2019 06:15 PM
