Starting Problem along with sparks!
Old Jan 8, 2010 | 11:37 PM
glmtd's Avatar
Default Starting Problem along with sparks!
Hi, I'm new here. I own 1995 Land Rover Discovery 3.9. Car died a few days ago and now won't start. It cranks over, but doesn't start. Originally I thought it was spark plugs and spark plug wires, so I replaced them, triple checked firing order on the cap. I'm getting power to the coil and I'm getting spark on spark plugs. I'm getting fuel. Any ideas?
Also there is a huge spark that jumps between intake manifold and firewall. Never seen anything like it. Has anyone encountered this before?
Thanks for your help
Old Jan 8, 2010 | 11:51 PM
Mrmerlin's Avatar
check the ground wire for the engine to chassis. If you have a spark jumping then you should recheck your plug wires and coil wire something is not right
SMAR
Dec 31, 2013 11:43 PM
03discoman
Jan 22, 2010 11:03 PM
Pwn777
Nov 8, 2009 09:45 PM
IDAHODISCO
Sep 17, 2009 08:54 PM
brian891
Aug 24, 2009 10:12 PM
