Steady Drip Coolant Leak
Old Jul 11, 2010 | 06:15 PM
Disco C's Avatar
Exclamation Steady Drip Coolant Leak
03 Disco, 73000 miles. i have a steady drip coolant leak comeing from the front drivers side front corner of engine. I thought it was my A/C drains this morning. When I got off work it was still dripping. Any thoughts, advice or concerns would be greatly apreciated.
-C-
Old Jul 11, 2010 | 06:26 PM
AK Rover's Avatar
First thought is your head gaskets are failing. Sound exactly like what mine did when the head gaskets started to go. Another possibility is the water pump failing. Have the cooling system pressure tested and you'll know exactly where your leak is coming from.
Old Jul 11, 2010 | 06:51 PM
hilltoppersx's Avatar
could be the HG's could be anything. get the system pressure tested to make sure you figure out where the leak is coming from.
Old Jul 11, 2010 | 07:17 PM
lipadj46's Avatar
Either a front cover/water pump leak or a HG leak. Go to Napa a get a little bottle of coolant dye. That should tell you really quickly where it is originating from.
Old Jul 11, 2010 | 07:54 PM
Disco C's Avatar
Well just crawled under to take a better look since its cooled down. Only noticeable drip is comeing from the drivers side corner of the sump. No coolant any higher than that. Its looking like water pump or front cover gasket. recently had valley gaskets and water pump gaskets changed. Im now wondering if he ever put a new front cover gasket on.
As always THANK YOU MY LAND ROVER BROTHERS!
Old Jul 11, 2010 | 08:38 PM
lipadj46's Avatar
That sounds exactly like front cover leak. He probably did not do the front cover as it involves a significant amount of work. That being said it is a pretty straight forward job for a DIY'r
Old Jul 11, 2010 | 08:49 PM
Disco C's Avatar
Ya the water pump is new. So probably front cover. Lipadj46 how many miles did you have when you did your HG?
I will take it to the shop Wens and get it preasure tested/see how much this is gonna cost.
Thank you all!
Old Jul 11, 2010 | 08:51 PM
lipadj46's Avatar
I did my HGs and front cover at around 100k miles
yloDiscoII
Nov 9, 2013 12:22 AM
sickws6
Nov 28, 2011 12:30 PM
cipher982
Oct 19, 2011 08:08 PM
crainb45
Jun 4, 2009 08:49 PM
