steering damper
Old Feb 6, 2010 | 12:23 AM
JumPeR04's Avatar
Default steering damper
Which one whould be the best steer damper old man emu or bilstein also how tight should it be thanks
Old Feb 6, 2010 | 07:04 AM
AK Rover's Avatar
I had the OME on my D1 with the rest of the HD lift kit and I was really happy with it. Honestly I don't think you'll notice a difference between the 2 brands when it comes to a steering damper.
By how tight, do you mean how tight should the bolts be or how difficult to move the piston inside the damper?
Old Feb 6, 2010 | 08:11 AM
JumPeR04's Avatar
On both
Old Feb 6, 2010 | 08:30 AM
antichrist's Avatar
The bolts you tighten to within the torque range for the size. There are bolt torque tables on internet.
I don't remember how the piston was on my OME that I had on my Disco. It got all beat to hell so when I moved the damper to the front, I replaced it with a Bilstein which was very tight. In fact it was a bit of a struggle to compress it to install.
Old Feb 6, 2010 | 08:37 AM
bearcatfans's Avatar
The Rave manual states "tighten to 125 Nm (92 lbf.ft)"
Aaron
2003 se7 102,000 miles.
Old Feb 6, 2010 | 08:51 AM
JumPeR04's Avatar
After I get the damper. I will be going with same name for the shocks
Old Feb 6, 2010 | 09:26 AM
My vote is for the OME simply cause you never seem to have to wear them out.
Old Feb 6, 2010 | 12:55 PM
okdiscoguy's Avatar
If you go with OME, you can lift with springs later. If you go with Bilsteins, they are too short to lift. That said, I got a heck of a deal on Bilsteins and like them. I also have an OME stabiliser. Loads better than factory.
Old Feb 6, 2010 | 03:18 PM
antichrist's Avatar
WTF?
92 lbft is 14lbft higher than that for a 7/16" grade 8 bolt. And the damper fixings are only 5/16" or 3/8"
The Rave manual doesn't even provide a torque spec for the steering damper fixings.
Old Feb 6, 2010 | 09:23 PM
rj95lss's Avatar
I went OME and you could instantly tell the difference over stock. I have heard nothing but good things about Blistine too. I would just stay away from the Terafirma.
thehun
Mar 10, 2011 08:11 AM
N.Franklin
Nov 13, 2007 08:06 PM
Fonzie
Nov 1, 2007 08:55 PM
RedElephant
Jun 3, 2007 07:31 AM
anonimaus
Oct 29, 2005 06:22 PM
