Steering issue
on
Steering issue
I've been trying to search for this issue, but it is coming up fruitless. I saw it mentioned before but can't find it. Here goes:
2003 disco 60k miles. When I hit a bump on the highway(which is pretty common in KY!)the steering has a tendancy to jump to the left or right a little. I think it isa commonsteering problem where the tires go in the air a little, you keep the wheel straight, however the tires are landing at a slight turn. On one bridge yesterday, I drove over a 3 inch gap that is at a 30 degree or so angle on the road. My tires caught this gap andthey turned towards the right hand wall . Scared the **** out of me. I'm not certain that the steering wheel is moving with the tires when it does this.
My power steering pump seems excessively loud. I don't have another disco nearby to listen to. Perhaps it is not pumping as strong as it should? I'm a big time newbie with this stuff. Steering I'm afraid to touch so I'll probably leave it to a shop, I just want to get a handle on it first.
Thanks!
Thanks!
on
RE: Steering issue
Yep, I just found a thread on landroversonly.com where you addressed another individual with the same problem, and the steering stabilizer was the glaring candidate. That's going to be my starting point.
I flushed my power steering when I talked to you on the phone last, although I want to redo it because I'm not sure how thorough I did the job. I added some stabilizer also.
Thanks again Mike.
Thanks again Mike.
RE: Steering issue
I agree that a big steering shock will help but I had an issue with a DII exactly like this, at highway speeds hitting big bumps or bridge splits the cars steering wheel jumped or shook like mad,and wouldnt stop until the car slowed down.I looked at all the common stuff,shocks ,steering shock,tie rod ends etc and found nothing.
I finally focused on the steering box, didnt feel loose , the common top adjuster screw adjustment to get rid of play in the wheel.was properly adjusted, BUT the rack adjuster on the side of the box adjusts the tightness of the big gear in the box,(I used to rebuild these boxes all the time back in the 80's).I simply loosened the small allen set screw and turned the giant adjuster until it felt tight , then backed it off slightly, if its too tight the steering wont return to center.this can cause a leak here because the rack adjuster only has a flat o-ring seal,and I dont think you can get the seal kit anymore. But might be worth a try.
another choice is to just change out the whole steering box
RE: Steering issue
Disco Mike,
What is the best way to flush the power steering system. I'm having the same problems that I've been reading about with leaks. Just bought the '98 Disco with 123k miles. I've heard of taking a baster and sucking out the resevoir, refilling, running a couple days and doing it again and adding Lucas.
Thanks.
Thanks.
RE: Steering issue
My 97 power steering pump was leaking around the suction fitting. I first thought it was the hose from the reservoir and replaced that. The suction fitting is just pressed in and has an o-ring on it to seal it. I pulled out the fitting, replaced the o-ring and put a dab of black RTV on it and it looks like the leak went away. Just thought someone might want to know that before spending the big bucks on a new PS pump to fix the leak.
marv
marv
Vinndego
01-06-2014 11:14 AM
tunernewb92
10-20-2009 07:15 PM
