Steering Issues...
Old Dec 7, 2011 | 06:29 PM
  #21
dgi 07's Avatar
Originally Posted by yloDiscoII
It is very gentle...IMO at least...no splashing, not much action. I would think a failing pump would emit some of the classic power steering whines though wouldn't it?
Stranger things have happened.
Old Dec 7, 2011 | 06:33 PM
  #22
handsome rob's Avatar
It may a little more work but why not disconnect the drag link from the pitman arm and then cycle the system by hand with the wheels off the ground. If all that is good and no binding then turn the steering wheel while the engine is running and see what the pitman arm is doing. If both those look good then disconnect the steering shaft and look for binding.
The steering pump may not whine if it is still moving fuid although not at the speed it should. Usually I hear the whine when it is low on fluid or it is not pushing any at all.
Old Dec 7, 2011 | 07:03 PM
  #23
yloDiscoII's Avatar
Good to know about the pump potentially being a "silent killer." Thank you both for the help.
I spoke with my mechanic and we are going to start pulling things apart to try and test the individual components to try and narrow it down.
I'll post the results whenever that's done.
Old Dec 8, 2011 | 06:59 PM
  #24
yloDiscoII's Avatar
Originally Posted by grandkodiak
....does it coinside with a ujoints shape? might be jammed up with crud..
CORRECT!
Originally Posted by lordmorpheus
The intermittent binding described earlier leads me to think of u-joints in the steering shaft binding.
DING DING DING!
You guys are geniuses as well as life/money-savers. Obviously I am inept at spotting binding U-Joints on the steering shaft because when I first had my wife turn the wheel back and forth it the other day it seemed smooth.
But per GK's suggestion, a PB Blaster blast, a wire brush and some grease and I'm rocking and rolling again.
The offending U-Joint was the one right at the box. Thanks again guys!
Old Dec 8, 2011 | 11:20 PM
  #25
Glad you got it worked out, I am also glad you did not pull it all apart before you found the culprit too.
Old Dec 9, 2011 | 08:28 AM
  #26
grandkodiak's Avatar
Glad it was somethin simple!
Discodude
Jan 26, 2011 09:46 PM
oljohnboy
Aug 30, 2010 09:04 PM
alexr54
Feb 7, 2010 03:43 PM
yukonridin23
Oct 26, 2009 11:14 PM
GodSavetheQueen
Jan 9, 2008 06:53 PM
