Steering Knuckle Maint?
1998 Disco. How do I grease the front steering knuckles? I assume the Square nut on the top. But what grease? I read on here somewhere to use CV axel grease, but want to be 100%.
Thx so much.
Thx so much.
How mant miles on your truck, when were either of the diffs serviced? Rover makes a swivel grease, comes in a small pouch, one for each side, Atlantic British and others have it. What about your gear oil and even more so your hub bearings and swivel pre-loads, when were they last set and or regreased?
130k on the truck, not sure when they were last serviced, just bought it. I checked the rubber seal around both sides. No leaks cracks or anything like that. No rust on the knuckles. Matter of fact they look new. Was I correct in my assumption that I fill via the square bolt?
$10 at the lawnmower shop that I use.
