Steering wheel vibrations
Old May 14, 2007 | 01:27 PM
RedElephant's Avatar
Default Steering wheel vibrations
Hi,
I just noticed there are some vibrations in my steering wheel at about 50mph. I'm wondering if this is just a matter of balancing the wheels, or possibly the steering system damper (stabilizer?) needs to be replaced. Or something else?
Anybody has similar problems?
The truck is 03 D2 with about 50,000 miles on it.
Thanks,
Adrian
Old May 14, 2007 | 01:33 PM
Aquaholic's Avatar
Default RE: Steering wheel vibrations
Balance and rotate your tires.
Old May 15, 2007 | 08:23 AM
It will also be a warn out stabilizer and possibily be your front drive shaft starting to fail, which is very common and expensive if not caught in time. Crawl under your truck, look at the double cardon housing that attaches to the t/case, look and see if you have grease fittings on the 2 u-joints inside that housing, if you don't, get it rebuilt ASAP cause when it lets go it can take the tranny with it, around $7000 for starters.
Mike
CodyNC
May 20, 2008 04:55 PM
stevenramsey
Apr 16, 2007 12:36 PM
blackdisco2001
Mar 10, 2007 02:14 PM
dewhorse
Mar 27, 2006 11:14 AM
Bene
Apr 27, 2005 12:56 AM
