Steering whine
Steering whine
Is the only source of a power steering whine/groan the pump? I am getting a near constant noise that goes almost away with engine speed. I replaced the power steering pump a couple years ago, I think it was leaking. So I put in some blue devil, leak stopped but I wonder if it attached to the noise. It gets worse when turning.
would the rack make noise? Or is the pump the culprit?
I wonder if the reservoir filter is plugged and starving the pump? I'm thinking i will pull it apart tomorrow to see if that is an obvious problem.
Or if I just need to replace the pump and reservoir.
Any thoughts are appreciated.
It stopped the leak, I think its the pump. I pulled the reservoir, it was jammed w black stuff. Cleaned it out the best I could and poked some holes in the filter, figuring it was getting replaced anyway. Its better, a bit quieter, but still not right.
I refllied it w Lucas, might be part of the reason it is better. But I think i need to replace the reservoir and the pump. PITA, just did the pump a couple years ago. I wonder if it is worth doing the hoses at this point.
Modern polymers
Using additives is a way to buy time, like Harv mentioned, until a real repair can be made, and sometimes they can last for years and years.
Alex_M (02-20-2023)
Not sure if the two are related, but I put in fresh fluid and started bleeding it. and fluid GUSHED out from near the rack. It bled from the nipple fine, but poured out on to the ground. It looked to be coming from below the pump, so I am thinking it has to be the rack. Or maybe the hose to the rack. I think I need to start looking at the rebuild kit, or a reman unit. I would not be surprised if the Blue Devil destroyed the system somehow. Completely unfounded, but magnitude of failure in the rack seems unlikely to have been a gradual leak. I will have to get under there and look more closely. I suppose it could be where the hose goes into or out of the rack, but the amount of fluid was huge. probably a liter in 5 seconds.
This is one of those systems where I have to pull it all apart, does it make sense to just replace everything, hoses, rack, pump?
