Steering whine
Old Feb 18, 2023 | 07:00 PM
redrover75's Avatar
Default Steering whine
Is the only source of a power steering whine/groan the pump? I am getting a near constant noise that goes almost away with engine speed. I replaced the power steering pump a couple years ago, I think it was leaking. So I put in some blue devil, leak stopped but I wonder if it attached to the noise. It gets worse when turning.
would the rack make noise? Or is the pump the culprit?
I wonder if the reservoir filter is plugged and starving the pump? I'm thinking i will pull it apart tomorrow to see if that is an obvious problem.
Or if I just need to replace the pump and reservoir.
Any thoughts are appreciated.
Old Feb 19, 2023 | 07:46 AM
Alex_M's Avatar
Always the pump. You might try some lucas power steering sauce. Generally not a fan of additives, but that one I've had really good luck out of.
Old Feb 19, 2023 | 02:29 PM
Harvlr's Avatar
And I think the additives only buy you time. My understanding is that they swell the seals which can stop the leak, but it also deteriorates all the seals in the system.
Old Feb 19, 2023 | 03:14 PM
Alex_M's Avatar
I've heard the same, but only as hear-say. No evidence I've seen. I've run it for four years in my longest vehicle that's had it with no issues.
Old Feb 19, 2023 | 05:19 PM
redrover75's Avatar
It stopped the leak, I think its the pump. I pulled the reservoir, it was jammed w black stuff. Cleaned it out the best I could and poked some holes in the filter, figuring it was getting replaced anyway. Its better, a bit quieter, but still not right.
I refllied it w Lucas, might be part of the reason it is better. But I think i need to replace the reservoir and the pump. PITA, just did the pump a couple years ago. I wonder if it is worth doing the hoses at this point.
Old Feb 20, 2023 | 11:09 AM
JohnZo's Avatar
Default Modern polymers
Old style stop leaks used mineral spirits. They worked by swelling the rubber seals a bit, so they can cause harm. Newer additives use polymer ingredients which help soften a seal that has hardened and smooths rough spots to stop leaks. The actual ingredients depend on which brand you use. Some companies spell it out, so I tend to use those vs the top secret brands.
Using additives is a way to buy time, like Harv mentioned, until a real repair can be made, and sometimes they can last for years and years.
Old Feb 20, 2023 | 01:26 PM
redrover75's Avatar
Not sure if the two are related, but I put in fresh fluid and started bleeding it. and fluid GUSHED out from near the rack. It bled from the nipple fine, but poured out on to the ground. It looked to be coming from below the pump, so I am thinking it has to be the rack. Or maybe the hose to the rack. I think I need to start looking at the rebuild kit, or a reman unit. I would not be surprised if the Blue Devil destroyed the system somehow. Completely unfounded, but magnitude of failure in the rack seems unlikely to have been a gradual leak. I will have to get under there and look more closely. I suppose it could be where the hose goes into or out of the rack, but the amount of fluid was huge. probably a liter in 5 seconds.
This is one of those systems where I have to pull it all apart, does it make sense to just replace everything, hoses, rack, pump?
Brandon318
Aug 2, 2021 04:32 PM
Brock88
Mar 23, 2018 03:17 PM
jfall
Jan 20, 2018 05:59 PM
jayg
Jun 14, 2012 06:21 AM
gavone1976
Jan 22, 2012 05:58 PM
