Stepper Motor
Old Feb 4, 2006 | 11:30 PM
xb70valkarye's Avatar
Default Stepper Motor
Done anyone know if there are any other brand or types of stepper motor that would fit in a 1996 LR dicsovery. I am not sure if it is the problem so I would prefer not to spend the big money to buy it from LR. Thanks
Old Feb 5, 2006 | 01:00 AM
Bait's Avatar
Default RE: Stepper Motor
Very unlikely that your stepper is bad. What is your concern ?
Old Feb 5, 2006 | 05:15 AM
Lighting90's Avatar
Whats a stepper motor then? Would that be the alternator, (the big magnet and coil thing)
What is the problem, describe what is happening and you never know, someone here might know what is wrong, or what to check for first.
Old Feb 5, 2006 | 04:44 PM
mikemeyer0's Avatar
No there are really no after market stepper motors. Whats you problem, stepper motors usally don't go out very east. what are the symtoms? why do you belive its your stepper motor?
Old Feb 6, 2006 | 02:26 AM
MadBilly's Avatar
what is a stepper motor?
Old Feb 6, 2006 | 03:00 AM
mikemeyer0's Avatar
ORIGINAL: MadBilly
IAC Valve, Intake Air Control Valve
Old Feb 6, 2006 | 11:12 PM
As said by mike its the intake air control valve. I know there is a Chev IAC that will fit on the 3.9 but not the 4.0. The reason I think it is the stepper motor is that the vehile did not idle most times when started warm. It would start and then just quit. I tried just turning up the idle and it works when the stepper motor is malfunctioning but then idles too high when it works. So the one time it worked I disconnected the wiring to the stepper motor to freeze it in that position and now it idles fine. Hence the stepper motor. I know the idle air will not be accurate with change of altitude or exterme temperature changes, hence I want to replace it.
Old Feb 7, 2006 | 02:39 AM
mikemeyer0's Avatar
yea don't know of any other manuf. that will work, you could try eletrical contact cleaner on the MAF and get it nice and clean and see if that helps any.
Old Feb 7, 2006 | 03:40 AM
Is the MAF the mass airflow sensor and if so where is it? Thanks for the quick reply
Old Feb 7, 2006 | 03:07 PM
mikemeyer0's Avatar
ORIGINAL: xb70valkarye
yep, and it is between the throttle body and the air filter, search a search enginge for "MAF cleaning" and it will come up with a bunch of info for you on doing it, it is easy. a lot of websites will tell you to use carb cleaner but you will be better of using eletrical contact cleaner in a spray can. good luck
ColeRover
Feb 9, 2011 07:05 AM
willlane
Nov 6, 2007 09:46 PM
eccmoto
Nov 3, 2006 12:56 AM
disco boy
Sep 28, 2006 09:27 PM
MilitantGrunt
Mar 15, 2006 11:00 PM
