Sticking Throttle Body Valve
Old Jul 22, 2011 | 04:02 PM
jgalderman's Avatar
Default Sticking Throttle Body Valve
How do I keep the throttle body from sticking. i cleaned it and it seems to be jamming instead of being hung up bu gunk. Is there an adjustment?
Old Jul 22, 2011 | 04:56 PM
0304Disco's Avatar
It shouldn't to be adjusted. See if you can move the TB easily by placing your hand on the end where your throttle cables attach and rotating the TB shaft counter clockwise. If it don't move freely make sure the Tb inner housing is clean with no obstructions making contact with the butterfly valve. If this is good I'd say your problem is with the throttle cable. Possibly some corrosion in which case I'd disconnect the cables at the TB and see if I could some lube inside the cable sheth.
Old Jul 24, 2011 | 05:52 PM
jgalderman's Avatar
Thanks for the feed back. I figured it out the throttle cable was a little loose. I tightened it up and it is working great.
ClayinSA
Nov 29, 2017 10:15 AM
SenatorPerry
Jul 15, 2013 10:28 AM
Spencerfitch
Oct 11, 2010 10:18 PM
louianquin
Freelander
Jun 11, 2008 02:53 PM
Doss
Mar 26, 2006 06:00 PM
