Sticky Ignition Switch After Transfer Case Change
Old Nov 23, 2018 | 02:00 AM
The Deputy's Avatar
It was 19 degrees yesterday morning, with a windchill bringing it closer to 9°F...so with that being said...nothing is "super simple and takes just seconds to do". Everything here is "super difficult and takes ten times longer than it should"...lol.
​​​​​​​ Brian.
Old Nov 23, 2018 | 02:29 AM
Best4x4's Avatar
Sorry I can’t help with the weather lol.
Old Nov 23, 2018 | 09:31 PM
garrddogg's Avatar
earlier this year we had an 04 cast installed in our 03, the guy that installed it put in the shifter rotated 90 deg clockwise. the key would not come out due to the transfer case. it took me almost 5 hours to prove to him it wasn't right. then they rotated it to the proper position and viola it all worked!
Old Nov 24, 2018 | 05:02 AM
The Deputy's Avatar
Trying to wrap my head around this, so you're saying he had the hi/low/CDL shifter mounted sideways?
Brian.
Old Nov 24, 2018 | 07:49 AM
garrddogg's Avatar
Cool
Brian.
I $hit you not! and hes a long time trans and diff shop owner.
Old Nov 25, 2018 | 12:07 PM
acg's Avatar
acg
Here is an update. It is appearing the transmission cable tension could be the root cause.
I now slightly jiggle the P in the transmission lever if the key happens to get stuck in the ignition lock. It has been working to get the key out. Looks like a new ignition switch replacement is not needed.
The shop performed a transfer case change recently and they could have made the transmission cable a little too tight.
Old Nov 25, 2018 | 03:53 PM
The Deputy's Avatar
I'd still check for loose change under the shifter housing...a few dimes and pennies in the wrong spot keep it from moving all the way forward.
​​​​​​​ Brian.
Old Nov 25, 2018 | 03:55 PM
Best4x4's Avatar
Loosen the 13mm nut on the XYZ switch that connects the PRND321 assembly to the XYZ switch, and take up 2mm of slack. If you aren't certain how much to do then use a marker on the rod before you loosen it to help in getting the adjustment right. I know I don't live up north, but I've done this adjustment in a gas station parking lot with a red hot engine/exhaust and it took me just a few minutes, then you'll be home free after that.
Also what Deputy suggest as I have seen dimes be a PITA under some PRND321 shifter bezels. That takes 10 seconds to inspect! Just be gentle when removing the assembly. Yank the Shifter **** straight up, then gently pull up on the bezel and then you'll either find a ton of treasure or maybe some old food lol.
Old Nov 25, 2018 | 06:03 PM
acg's Avatar
acg
I haul my sons around in the Disco. I bet there will be coins, potato chips, used band aids, dirty socks, etc ....
Thanks again guys!
duscarter
Sep 10, 2018 08:06 AM
RichDisco
Oct 21, 2015 09:12 PM
jgyorkii
Dec 11, 2014 07:09 AM
geoffthepoolguy
May 10, 2012 07:25 AM
aivie82
Sep 7, 2009 05:48 PM
