sticky throttle
sticky throttle
Just finished replacing the head gaskets, got the truck back together, fired it up and once it caught it revved to 4 grand right off the bat, which i was trying to avoid given that my handy work was untested. i adjusted the cables, i figured that the retaining nut got moved during surgery. once they were adjusted back to were they should be i started it back up and it idled fine. once it was warm i gave it a rev and it stayed there, i gave the gas pedal a quick little tap and it dropped back down to idle. Is it just a matter of lubrication? i wouldn't be nervous to do that if i had not just finished the head gasket job, there are just a lot of variables i want to make sure i did not overlook something else first. also maybe totally unrelated but there is a vibration/buzz noise coming from the instrument cowl when the ignition is on both with and without the engine running. it might have been like that for a long time but i am super vigilant tracking down noises right now.
