sticky throttle
Old Feb 24, 2014 | 08:22 PM
coloboy's Avatar
Default sticky throttle
Just finished replacing the head gaskets, got the truck back together, fired it up and once it caught it revved to 4 grand right off the bat, which i was trying to avoid given that my handy work was untested. i adjusted the cables, i figured that the retaining nut got moved during surgery. once they were adjusted back to were they should be i started it back up and it idled fine. once it was warm i gave it a rev and it stayed there, i gave the gas pedal a quick little tap and it dropped back down to idle. Is it just a matter of lubrication? i wouldn't be nervous to do that if i had not just finished the head gasket job, there are just a lot of variables i want to make sure i did not overlook something else first. also maybe totally unrelated but there is a vibration/buzz noise coming from the instrument cowl when the ignition is on both with and without the engine running. it might have been like that for a long time but i am super vigilant tracking down noises right now.
Old Feb 24, 2014 | 08:29 PM
coors's Avatar
Sounds like the throttle is getting hung up mechanically. Find a picture on the inter-web or RAVE and Double check your work against it.
Old Feb 24, 2014 | 08:30 PM
coors's Avatar
What about the ICV. Idle control valve. Anyway that's not installed properly? Loose or damaged connection?
Old Feb 25, 2014 | 07:43 AM
acamato's Avatar
Try disconnecting the cable form the throttle body to see what is hanging up.
SenatorPerry
Jul 15, 2013 10:28 AM
Caleb.hunter
Apr 16, 2012 07:18 PM
Philhowe
Mar 6, 2008 11:58 AM
wesk
Jan 23, 2008 01:55 PM
supra92
Jul 13, 2007 07:44 AM
