still having idle problem!!
my '95 is still ideling at 1500rpms!! I have tried everyones suggestions with no luck!! Here is a list of what I have tried.
1. cleaned MAF
2. Cleaned idel control, also disconnected and engine went to 3000rpms.
3. new plugs and wires.
4. disconnected battery and left off for twelve hours.
I just spent almost $800 on fixing my front sunroof, so I really don't want to take her in to the dealership. It's prob something simple anyhow.
please,please help me!!
1. cleaned MAF
RE: still having idle problem!!
maf will set a light (is there a light) next cant clean a maf next there is a stepper motor for idle control that you can clean next if there is a light you probably have a vacume leak. Just for s--ts and giglles check throttle body linkage and pull the boot make sure the butterfly comes all the way home
I was looking around at my local pick and pull and came across a LR "County estate". When I lifted the hood I found a 3.9!!! All of the sensors were there!! I pulled the TPS, idel control and the MAF!! I paid $13 for all!!!!! I about died!! Since I was pretty sure the idel control was ok, I decided to change the TPS. As it turns out the one from the yard had a round plug and mine was square, so I spliced the end from my TPS to the one from the yard!! My LR now idels perfect!!! Thanks for the help, I have learned quite a bit about my LR From this forum. I hope this helps someone in the future.
