Still a head gasket leak?
Old Dec 28, 2019 | 01:31 PM
blakslee720's Avatar
Default Still a head gasket leak?
So I just finished a HG, timing cover, water pump and pan gasket job on my 04 disco
Its running but says there’s a misfire on 1 and 7. Spark plugs look ok and there’s not a consistent steam show coming out the tailpipe
So I’m suspecting a small HG leak still from the cooling jackets right next to cyl 1&7
All the coolant is drained (rad is also new) and there’s nothing in there but water. I’m about to put Blue Devil pour and go in to try and solve the problem
Any advice or other suggestions before I do this?
Old Dec 28, 2019 | 01:50 PM
redwhitekat's Avatar
Yes I would pressure test coolant system to see if in fact you have a leak
Old Dec 28, 2019 | 01:52 PM
1 and 7 are on the same coil pack you might have switched wires on the coil pack by mistake. I did that once when replacing coil packs.
Thsts why I got the relocation kit
Old Dec 28, 2019 | 02:39 PM
User's Avatar
I would double and triple check the coils.. It's my tradition to mix them up every time I do a HG.
Old Dec 28, 2019 | 03:21 PM
yes they are routed correctly
also getting p1300
Old Dec 28, 2019 | 03:50 PM
So during my double check of the plug wires, I thought 1&7 were wrong. So I swapped them and then realized I had it right the first time and put them back correctly.
cleared the codes, didn’t throw any at idle like is has been. Drove 2.5 miles around the neighborhood and felt great
Not 100% sure about coolant leaks into the oil but it is running well. Going to add antifreeze in a bit. Then I’ll keep an eye out for chocolate milk
difrentbob
Mar 15, 2014 10:44 AM
utah95
Feb 6, 2014 04:10 AM
01d2Jeff
Jan 23, 2012 08:08 PM
photocrimes
Jan 30, 2011 01:15 PM
lipadj46
Sep 11, 2009 04:59 AM
