Still need power steering help
Ok, so I put in an other Power steering pump. I get the same thing as I did with the first replacement (after I removed the plug from the res.)
I get spurting out the bleeder screw at first and then it ends. I was getting a swirling in the res and now, i'm not too sure (although it does appear that there is movement in there)
Is there another component that could have gone bad after sitting for a year in the woods dry? Is there somewhere else I should look?
I do have a tube on the bleeder screw and when I turn the wheel to the right, fluid moves out...when I turn the wheel to the left, it sucks fluid back on...
Thought, suggestions?
Thanks again,
Steve
Thanks again,
Steve
johnnyjohnny
09-26-2019 09:37 PM
