Still need power steering help
Old Mar 9, 2010 | 10:56 PM
jrm123180's Avatar
Default Still need power steering help
Ok, so I put in an other Power steering pump. I get the same thing as I did with the first replacement (after I removed the plug from the res.)
I get spurting out the bleeder screw at first and then it ends. I was getting a swirling in the res and now, i'm not too sure (although it does appear that there is movement in there)
Is there another component that could have gone bad after sitting for a year in the woods dry? Is there somewhere else I should look?
I do have a tube on the bleeder screw and when I turn the wheel to the right, fluid moves out...when I turn the wheel to the left, it sucks fluid back on...
Thought, suggestions?
Thanks again,
Steve
Old Mar 10, 2010 | 04:51 AM
antichrist's Avatar
Get a tube that fits it and stick it in a bottle of PS fliud.
Old Mar 10, 2010 | 06:16 AM
Rovin4life's Avatar
is there any noise or just hard steering? if its the hard steering had a steering box break internally causing the issue.
Old Mar 10, 2010 | 08:35 AM
jrm123180's Avatar
It is hard steering...are the boxes easy to repair?
johnnyjohnny
Sep 26, 2019 09:37 PM
LICKDLISH
Mar 17, 2017 10:28 AM
joshrave
Dec 12, 2014 10:59 AM
#1BRONCOFAN
Jan 18, 2014 12:29 AM
cobbcj7
Nov 18, 2011 09:33 PM
