Still no Spark on Cyl 4 & 7 after replacing plugs, wires, and coils
Old Jul 26, 2011 | 02:44 PM
rohnbarrow's Avatar
Default Still no Spark on Cyl 4 & 7 after replacing plugs, wires, and coils
2001 Discovery II w/ 135K
Problem started with P1300, P0304, P0307
No spark on cylinders 4 & 7
I’ve replaced the wires, plugs, and coil packs.
Still getting P1300, P0304, P0307
What is the next step to diagnose the system?
Old Jul 26, 2011 | 05:04 PM
dgi 07's Avatar
how did you verify that you have no spark on cylinders 4 and 7.?
Old Jul 26, 2011 | 06:51 PM
rohnbarrow's Avatar
Default Inline spark plug tester
I used an inline tester. All other plugs test OK.
Old Jul 26, 2011 | 07:09 PM
With new coils. plugs and wires, there isn't anything that can cut the spark. Are you sure you have no spark? If it were mine, I would do a compression test.
Old Jul 26, 2011 | 07:48 PM
rohnbarrow's Avatar
Default ECM Problem?
Could there be a failure on pin 7 of ECM Connector 5 (C0638) which fires cyl 4 & 7? How would I check that to rule it or out?
Compression checked out OK.
Old Jul 26, 2011 | 07:56 PM
rohnbarrow's Avatar
Default P1300, P0304, P0307 are still showing up
Also, the system is throwing the following codes:
P1300
P0304
P0307
Sometimes a P0300.
I'm stuck.
Is there a fusible link/relay?
Old Jul 26, 2011 | 08:22 PM
dgi 07's Avatar
check the ground point for the ecm....I helped a guy a while back with a similar problem and one of the rover techs on here recommended checking the ground. Never got back to us if it works or not, but if he never got back and said it didnt work, im gonna make the assumption it did.
Old Jul 26, 2011 | 09:19 PM
rohnbarrow's Avatar
Thank you. I'll take a look at that tomorrow.
Old Jul 27, 2011 | 10:32 AM
kenk's Avatar
Do 4&7 share a coil? Just thinkin out loud, maybe a bad connection, or no juice getting to the coil?
Old Jul 29, 2011 | 10:31 AM
rohnbarrow's Avatar
Yes, they do share the same coil. I need to somehow test the connection between the ECM and the coil. It could be the connection or the ECM. I don't know yet. And, I haven't a clue on how to test it yet.
