Still no Spark on Cyl 4 & 7 after replacing plugs, wires, and coils
Old Jul 29, 2011 | 06:46 PM
dgi 07's Avatar
im assuming you have a multimeter. disconnect the ecm and the coil. do a resistance test between the ecm connector and the coil connector. you already know the pin for the ecm....all you gotta do is find it on the coil connector. if the connection test ok, then its your ecm....hopefully, you checked your grounds as well.
Old Jul 31, 2011 | 02:44 PM
rohnbarrow's Avatar
I checked the ground it was ok.
I got the multimeter out and rigged up test leads and everything checked out OK on all the connections. So, that pretty much makes it the ECM.
Ideas on the next step?
Any ideas on the next step?
Will the new/used ECM need to be programmed with a TestBook/T4?
Old Jul 31, 2011 | 02:45 PM
rohnbarrow's Avatar
Where should I get a used ECM?
Old Jul 31, 2011 | 03:33 PM
Here is just a wild thought off the top of my head, have you replaced the crank sensor?
It is cheap and guaranteed to fail and or throw all kinds of monkey wrench's into the works.
That is what controls your spark.
Old Jul 31, 2011 | 04:31 PM
rohnbarrow's Avatar
I replaced the CKP six months ago. It failed and the Disco just stopped. Replaced the CKP and the Disco came right back to life.
Old Jul 31, 2011 | 05:02 PM
Ok, see, you didn't mention that before.
Old Jul 31, 2011 | 07:09 PM
dgi 07's Avatar
check the classified first. try multiple lr forums.....then, google it
ebay has then as well
Old Aug 24, 2011 | 10:35 AM
lesjonpool's Avatar
6th Gear
Default Any resolution on this issue?
I am having a similar problem. I replaced all 8 spark plugs and wires on my '99 Disco II but am still having the following fault codes after 150 miles worth of driving:
P1300 - Multiple Misfire
P0304 - Cyl 4
P0307 - Cyl 7
P0300 - Multiple misfire, excess emissions
P0308 - Cyl 8
Note that the vehicle seems to be running fine. There is no roughness or lack of power.
Thanks!
Jon
GiGi La Luz Ramone
Aug 31, 2013 04:46 PM
pdowning6
Apr 30, 2012 08:38 AM
topfrog007
Apr 19, 2012 12:43 AM
me 2
Apr 11, 2012 08:56 AM
kumbhani123
Jun 12, 2007 04:22 PM
