Still Overheating
Old Oct 27, 2013 | 01:52 PM
walkingzach's Avatar
Default Still Overheating
I have a 2003 Discovery II with 112,000 miles that I bought less than a year ago.
I had overheating issues from the start and have replaced almost the entire Cooling System.
I have an ultraguage and right now I am running at a pretty constant 220 degrees.
Here is what I have replaced so far...
  • thermostat
  • radiator
  • water pump
  • radiator hoses
  • head gasket seals
I replaced the thermostat, radiator and water pump myself and that brought the temp down from 230s and 240s to a cool 205.
But I was still leaking coolant all the time so I had a shop replace the head gasket seals...which was $2000 to bring my temp back up to 220.
I dont know what else I could do, replace, or repair to get to a cooler temperature.
any suggestions??
UPDATE - ISSUE RESOLVED
I replaced the thermostat and expansion tank coolant cap and now am seeing temps around 194 degrees and I haven't seen temps above 200 degrees yet.
The whole change only took about hour and cost me $80 including the coolant.
Here are the parts I used.
  • Motorad 439-180 Thermostat
  • URO Parts PCD000070 Expansion Tank Cap
Old Oct 27, 2013 | 02:10 PM
dusty1's Avatar
What degree tstat are you using
Are u sure there is no air in system
Heater core may be sludged up
Old Oct 27, 2013 | 02:11 PM
Madlands's Avatar
I'd put a new cap on the coolant tank to be safe. Besides that did you go with 180 soft spring thermostat or stock thermostat?
Old Oct 27, 2013 | 07:27 PM
i had the 180 tstat when i replaced it myself but i think when i got the head gasket seal replaced they put in a different one.
i was planning on putting in the 180 tstat soon so ill just get a new coolant cap too
Old Oct 27, 2013 | 07:58 PM
Madlands's Avatar
Go with the grey 180 degree thermostat. I'm not sure who had them but I'm sure someone on here can tell ya.
Like dusty mentioned though you could have a clogged up heater core. On the top passenger side firewall you'll see two hoses running into it. Those are to your heater core. I would pull those and try to flush it out if the new thermo doesn't help.
Old Nov 3, 2013 | 10:57 AM
Just to give everyone an update I replaced the thermostat and the coolant cap that seemed to work.
I was seeing about 220 all the time and now I am seeing a cool 194 and so far it haven't seen it above 200.
Here is the thermostat and coolant cap I used.
Old Nov 3, 2013 | 09:36 PM
jfall's Avatar
I would put in the standard Land Rover replacement 180 degree thermostat.
Not the Motorad. LR thermostat is about $70 or so. Yes a rip off but..
gli_ryan
Aug 9, 2011 10:57 PM
Disco2Fever
Aug 1, 2011 04:00 PM
phidelt583
Jan 19, 2009 07:01 AM
alanski
Sep 19, 2008 08:40 AM
