still shutting off
still shutting off
So for several months my truck is shutting off on me, no lites are showing up, the only code that showes in the history is off road use, well I havnt been off roading with it yet.Any clues would be a great help.O land rover couldnt figure it out, and my mechanic has tryed out a few new programs on his system and it dosnt show a thing.
thank you for looking.
so far, I replaced the batt. cable ends, alternater, mass air flow, crank sensor, idal air, spark plugs, wires, and tps.Land rover cant figure it out. My local mechanic has used a few differnt computer systems that are made for Land rover, and they cant pick any thing up.This is the worst truck I have ever owned.
Thanks for your reply!
1. Carry a spare spark plug.
2. When it shuts off, if it won't restart at once, the carnk sensor coulf be the issue. Unplug a spark wire, attach spare plug, lay on manifold, crank and check for sparks. Usualy a bad crank sensor wants to cool down before it will work again.
3. Loose wire or bad inertia switch - killing the main relay, or loose fuse (sometimes hairline crack with a mind of their own), or fuel pump relay. Would go over the underhood fusebox for everything being clean and tight top side and plug ins below.
4. Could be a loose ground somewhere.
5. Not many things stop the engine while running.
RPMS will drop, then some times it will die, when it does die no warning lites, then it starts up like nothing happened, no fault codes, and no fault codes in the history.Ive replaced just about every thing that has been sugested to me.I have cheaked all the ground wires to, they are squeky clean.I wish this truck would just give up and burn to the ground!
thanks for your replys!
