still shutting off
Old Jan 29, 2012 | 07:55 PM
ajmille's Avatar
Default still shutting off
So for several months my truck is shutting off on me, no lites are showing up, the only code that showes in the history is off road use, well I havnt been off roading with it yet.Any clues would be a great help.O land rover couldnt figure it out, and my mechanic has tryed out a few new programs on his system and it dosnt show a thing.
thank you for looking.
Old Jan 29, 2012 | 08:34 PM
Rough road fault, it is not off road use, it is a ABS code.
Have you replaced the cranks sensor?
Which is the #1 reason a DII just shuts off for no reason.
Old Feb 5, 2012 | 11:30 AM
ajmille's Avatar
so far, I replaced the batt. cable ends, alternater, mass air flow, crank sensor, idal air, spark plugs, wires, and tps.Land rover cant figure it out. My local mechanic has used a few differnt computer systems that are made for Land rover, and they cant pick any thing up.This is the worst truck I have ever owned.
Thanks for your reply!
Old Feb 5, 2012 | 11:43 AM
Wish I could be of help man, good luck.
Old Feb 5, 2012 | 11:47 AM
RoverMasterTech's Avatar
Jesus dude... maybe a little background? like does it restart instantly? does it have to cool off? is it when idling? driving fast? Check the Idle stabilization valve, if someone put the airbox lid on wrong and one speck of dirt gets in that valve it will make it stick.
Old Feb 5, 2012 | 11:48 AM
1. Carry a spare spark plug.
2. When it shuts off, if it won't restart at once, the carnk sensor coulf be the issue. Unplug a spark wire, attach spare plug, lay on manifold, crank and check for sparks. Usualy a bad crank sensor wants to cool down before it will work again.
3. Loose wire or bad inertia switch - killing the main relay, or loose fuse (sometimes hairline crack with a mind of their own), or fuel pump relay. Would go over the underhood fusebox for everything being clean and tight top side and plug ins below.
4. Could be a loose ground somewhere.
5. Not many things stop the engine while running.
Old Feb 5, 2012 | 01:58 PM
ajmille's Avatar
RPMS will drop, then some times it will die, when it does die no warning lites, then it starts up like nothing happened, no fault codes, and no fault codes in the history.Ive replaced just about every thing that has been sugested to me.I have cheaked all the ground wires to, they are squeky clean.I wish this truck would just give up and burn to the ground!
thanks for your replys!
Old Feb 5, 2012 | 02:00 PM
ajmille's Avatar
O, I swaped around relays that where the same, still the same, and I also bye passed the inertia switch.
Old Feb 5, 2012 | 02:40 PM
Chibrown's Avatar
Same thing happened to me. After replacing the crankshaft position sensor, it turned out I just needed a new fuel pump...(expensive fix)
Same thing MIGHT be happening to your truck.
Old Feb 5, 2012 | 07:04 PM
ajmille's Avatar
lol, forget to mention, I did replace the fuel pump
