Still Smokin from Exhaust....
At around 141,500 miles i had the heads resurfaced, head gasket job, pressure tested,
the whole nine yards.... today i went out and before i started it up, checked the coolant level, it was getting low in the expansion tank. Added coolant with the bleed screw out till it came out of the hole. i put the screw back in and started it up, and watched the coolant rise and come out of the overflow hose, then replaced the cap on the tank.
i had to go in the cargo area for some paper towels when i noticed white smoke from the exhaust.... what is causing this to smoke now that i have had head gaskets replaced?
Ok, you live in the New England area, have you never looked at your cars exhaust first thing in the moring before on a humid day or after it has sat for 12 hours on a cool night?
Moisture builds up inside the exhaust, this is normal for it to puff white smoke, just like in the winter time, until it is all burned off, totally normal, you are just parinoid because you just had work done.
Drive it for a week, keep a eye on the coolant, as long as the coolant level stays good you are fine.
If you need to add coolant then take a closer look at the exhaust, smell it, does it smell sweet?
And yes you can start/run a engine with the radiator cap off, as long as the system is full it wont suck air back into it.
I'm thinking that they did not completely bleed your system. After the head gasket job it may take a couple top offs until the coolant stays at the correct level. I was nervous after my head gasket job because I had to top my expansion tank off 3 times. It's been a couple weeks and no change in the level now.
I do check it and top it off when cold only, and i try to keep the level at completely full, altho it always puhes out the excess. Spike you were right, just moisture buildup inside the exhaust, later that day after I let it cool down completely, I started it up and let it run and I watched the tailpipe for smoke, which there was NONE. It rained the night before, so there had to have been a lot of water in exhaust.
question now.... these "Borla" exhausts, are they worth the $$$ ???
I found a used one that will fit my D2, to replace the rumbly exhaust that is no doubt original. (can leaks at the seam, you can see the leak on the driver side cat.)
Sean Price
12-30-2007 07:52 PM
