Stock CD changer mod?
Old Jun 10, 2010 | 01:34 PM
turf63's Avatar
Default Stock CD changer mod?
i have a 99 Disco I with a CD changer that i never use. Is it feasible/easy enough to splice the changer's wiring harness and put an ipod connector at the end of it. In an ideal world i'd run the wire up into the glove box where the ipod connector would charge my iphone and utilize the aux input on my factory stereo to play my ipod. If anyone has a wiring guide for the cd changer i'd be willing to try this as i dont really mind losing the cd changer if i FUBAR the project. thoughts?
Thanks,
Ryan
Old Jun 10, 2010 | 02:04 PM
okdiscoguy's Avatar
roverparts.com has a kit. There is also a write up somewhere that has one a guy made...
Old Jun 10, 2010 | 02:18 PM
turf63's Avatar
i looked pretty hard for the write up, i was trying to avoid redundancy but wasnt able to find one. Do you remember what section it was in, im willing to look again.
As far as roverland, ordering the part just takes all the fun out of it doesnt it?
Thanks for the info
Old Jun 10, 2010 | 04:03 PM
okdiscoguy's Avatar
it is atlantic british.... www.roverparts.com. I will see if I can find the hookup.
Old Jun 10, 2010 | 04:17 PM
okdiscoguy's Avatar
http://www.rangerovers.net/rrupgrade...odadapter.html
other forum. The RRC and D1's have the same hookup.
Old Jun 10, 2010 | 04:41 PM
Check out this link for a great kit, http://home.valornet.com/splacket/SpecialParts.htm
Old Jun 10, 2010 | 07:02 PM
joecmiami's Avatar
5th Gear
this is what i used in my 03 disco, it's called GROOM AUDIO IPOD INTERFACE i use my ipod all the time and i've tried it with my iphone and it also works perfectly, you control everything from the stereo as if you were using the cd, and cd1 cd2 cd3 cd4 and so on it will be your playlist on the ipod, it charges it and it shut it down when not in use, i can provide pictures if you want, it connects behind the radio where the cd changer plugs in, so no more cd changer after all you're going to have a lot more music on your ipod/iphone
the link takes you directly to the groom audio page, you might find it cheaper on ebay
http://www.gromaudio.com/store/ipod_...interface.html
Old Jun 11, 2010 | 07:54 AM
turf63's Avatar
Thanks a ton for the help guys, i've seen a few people on here who've had success with the grom box. I found as i started to consider something like that at (or around $80) why not get all the functionality out of the phone and have it connect via bluetooth for phone calls for around $200. So now im thinking since it doesnt sound like an easy splice job, maybe go the crutchfield way. If i do end up with the new head unit and an external mic, i'll be sure to take pictures (maybe at the same time i do my saggy headliner) when i route the mic up the a-pillar and over the headliner.
Thanks again
Ryan
greenwade
Nov 4, 2010 11:24 PM
basketkase045
Jun 11, 2010 01:30 PM
Brokenrover
May 17, 2010 05:27 PM
SpeedAgent
Aug 1, 2008 02:47 PM
JRdisco1
Nov 9, 2005 06:14 PM
