stop squeal on brake pads
Old Jun 10, 2010 | 11:31 AM
pipjack's Avatar
Default stop squeal on brake pads
I posted a thread awhile back on replacing rotors and pads on both axles of my 04 disco. I need a little clarification. It was mentioned that I should put stop squeal on the back of the brake pads. Does this mean the part of the pad that faces the the caliper and not the rotor? Also something was mentioned about antiseize. Where does that go?
Thanks again,
Maggie
Old Jun 10, 2010 | 11:44 AM
okdiscoguy's Avatar
light amount of antisieze on the screw that holds on the calipers, and the squeal stop goes between the pad and the caliper. NOT on the pad surface.
Old Jun 10, 2010 | 11:48 AM
pipjack's Avatar
How long in general do I let the stop squeal cure?
Thanks for your reply,
Maggie
Old Jun 10, 2010 | 11:50 AM
okdiscoguy's Avatar
Should be on the can. 15 minutes per application, I think. Don't skimp on cure time or it will cut right through it the first time you hit the brakes.
Old Jun 10, 2010 | 01:18 PM
Also plan on a 2 quart brake flush/bleed to get a stronger pedal.
CapeRover
May 3, 2013 04:35 PM
gbob
Apr 25, 2013 03:50 PM
oysterhead
Apr 27, 2010 10:38 PM
ljdiscovery
Jan 17, 2009 01:35 PM
