Storing outdoors with no water pump?
Old May 22, 2021 | 06:46 PM
Tumbler's Avatar
Default Storing outdoors with no water pump?
I just acquired a D2 that I won't be able to begin working on for the next 3 months. The issue is there is no water pump on the engine and due to a seized/bent/welded water pump bolt, I won't be able to put the water pump back on easily either. Should I be ok to store this outside for 3 months without causing myself headaches down the line?
Old May 22, 2021 | 07:03 PM
greisinb's Avatar
It’s probably worth sticking something in to the open ports or at the very least taping them off (with painters tape so you can remove it later with minimal residue on the gasket surface). I would be worried about something crawling in that dark, moist environment and building a nest or some sort.
Old May 22, 2021 | 09:07 PM
Tumbler's Avatar
Thanks for confirming my concerns. I know what I'm doing tomorrow.
Old May 23, 2021 | 12:01 AM
Art H's Avatar
If you are worried about something building a nest.. steel wool will keep most everything out.
clint70
Oct 22, 2015 09:08 PM
primo
Apr 28, 2011 09:09 AM
doddsy
Jun 29, 2009 06:02 PM
RangyEvan.CountyLWB
Mar 19, 2009 04:21 PM
steveyogi
Sep 28, 2007 12:19 PM
