Strange Growling Sound 2003 Disco 2
Old Feb 5, 2020 | 12:48 AM
Nathan Stich's Avatar
3rd Gear
Default Strange Growling Sound 2003 Disco 2
Hello everyone! I am very confused to what this sounds could be coming from on my disco. It is in the lower portion of the engine bay but I attached a YouTube link. To describe the sounds is a constant growling. If anyone has any tips I should try to investigate further into thank you.
Old Feb 5, 2020 | 01:15 AM
Richard Gallant's Avatar
Bad air conditioning compressor or wierd bearing noise ?
Old Feb 5, 2020 | 04:19 AM
JUKE179r's Avatar
Welcome to the forum.
Sounds spooky.
Remove the serp belt and run the engine to see if you get the same sound and feel around/spin all the pulleys.
Don't run it too long though without the serp belt!!!!!!
Old Feb 5, 2020 | 06:26 AM
shanechevelle's Avatar
Sounds spooky.
And to promote Juke's good advice once you have the belt off, wiggle the pulleys and see if any of them wobble.
To gauge your water pump, wiggle the pulley with the fan still attached. If you get any movement your water pump is starting to fail.
cvhyatt
Oct 20, 2019 05:51 PM
Carlos Man
Oct 14, 2019 09:45 PM
thatbaldguy
Nov 25, 2016 09:28 AM
anteyv
Jan 31, 2013 09:36 AM
ZGPhoto
Oct 22, 2012 09:43 AM
