Strange misfire/no start
Old Dec 20, 2008 | 01:30 AM
dammad's Avatar
Default RE: Strange misfire/no start
I can do simple stuff like O2 sensors, oil change, etc. But not much more..
Old Dec 20, 2008 | 05:20 AM
rinmud's Avatar
anyone thought of checking the engine management ecu of a frosty??? think about the firing order and 1 6 then think 4 coil motor. a frosty is the thing what happens when a ecu plug gets wet and wella 1 flavor, white zinc oxide. pull the plug and look inside it. its very interestingly placed next to the battery, king of frosty. scott
Old Dec 20, 2008 | 09:51 AM
ORIGINAL: dammad
How difficult is it to switch the plug wires? They look like they disappear around the back of the engine and so look like a d*#ch to change.
Give me a shout, I'll be around most of the day.
Old Dec 20, 2008 | 01:52 PM
dammad's Avatar
Had a long run and after warmup was fine. However, 30 mins later, the damn thing won't start at all now..
Old Dec 20, 2008 | 02:04 PM
ORIGINAL: dammad
Interesting.. Can a crank sensor cause misfires too?
A crank sensor can not in any way cause a misfire, it will either stall your engine or not allow it to start.
Old Dec 28, 2008 | 01:51 PM
dammad's Avatar
Alas the saga continues on this one. New Crank Sensor fixed the no start problem. I sprayed the wires and the misfire seemed worse, so I switched to magnecor wires.
However, this all done, I *still* have a slight misfire. This morning the truck served up some check engine codes again. P300, P301 and P306 (misfires on Cyl #1 and #6). Do the question is what gives?
Are cyl #1 and #6 on the same coil pack? Please say they aren't so I don't have the pay the 3hr of labor to get them changed (the same as the plug wires).
Would an old MAF cause this?
Old Dec 28, 2008 | 04:05 PM
ORIGINAL: dammad
Looks like I missed DiscoMike.. Anyone else got ideas???
Did you PM me??
Old Dec 28, 2008 | 07:08 PM
dammad's Avatar
That was an old message.PM.. Alas the problem is still there after new plug wires and the crank sensor.
Landy95four"lift
May 19, 2013 07:35 AM
Gromeo
Jan 24, 2013 03:41 PM
armyeng
Mar 8, 2011 05:58 PM
nickd503
May 14, 2009 10:34 PM
riemer
Jan 27, 2007 12:42 PM
